This being first run, even with beta testers, i was anticipating some issues. But, you can tell the quality and attention to detail that went into this case. im really looking forward to getting the rest of it together once my parts arrive.
This riser cable has a perfect fit. color me impressed.
There was a reason my review of the beta case was basically all positives. Not that there weren't issues, but wintercharm was so on top of listening to feedback and listing out/executing fixes that I didn't feel it was fair to put him on blast. Plus, he himself openly discussed all the issues the beta testers found here and the KS page anywayThis being first run, even with beta testers, i was anticipating some issues. But, you can tell the quality and attention to detail that went into this case. im really looking forward to getting the rest of it together once my parts arrive.
I'm receiving the exact same experience.There was a reason my review of the beta case was basically all positives. Not that there weren't issues, but wintercharm was so on top of listening to feedback and listing out/executing fixes that I didn't feel it was fair to put him on blast. Plus, he himself openly discussed all the issues the beta testers found here and the KS page anyway
I'm
I have no regrets about spending $400+ on this case.
3090 (doesn’t) go brrrrrJust wait until you're running benchmarks. That's when Beta testers started freaking out.
I experienced the same on the z490i strix. For me this caused a small issue with the io not lining up.FYI for those receiving the first wave of cases. There's a kinda-sorta issue with an easy fix.
The standoff included is approx. 4mm OD and the standard appears to be 5.5mm (confirmed by measuring available NCase and 011D). The OD was small enough to fit through the asus strix x570-i screw holes leading to board flexing.
The fastest solution is to consistently apply pressure against the rear panel ports while tightening the screws. This will create a misalignment and allow one side of the standoff and screw to clamp the mobo.
If you have M3 nylon washers available, then use those instead. If you are still waiting for your case, then I recommend ordering M3 nylon washers with <10mm OD.
Hi,Quick word about the standoffs issue.
Thanks to @mxj1 and @Post-Newt I was informed of this rather quickly. I'm aware of the issue, and that this needs to be addressed, and we are going to address it.
Here's how we're going to mitigate this:
If this issue affects your motherboard, please reach out to us. We'll dispatch some nylon spacers to you. They will fit around your standoffs and hold your motherboard up, allowing you to secure it. To start this process:
1. Take a picture of your rear panel serial number
2. Take a picture of the issue
3. Send them to the support email on the card that came with your case.
Hi, I have the same motherboard as post, so I will encounter the same problems. I live in France and I don't want to bring washers from the USA to fix this little problem. Please tell me exactly what I should buy. I guess I'll understand better what's going on when I get the case. Thanks to
Hi,
I have the same motherboard as Post-Newt , so I will encounter the same problems. I live in France and I don't want to bring washers from the USA to fix this little problem. Please tell me exactly what I should buy. I guess I'll understand better what's going on when I get the case. Thanks to you guys
Which one ?
I like this fix much better than washers.
