JUST OVER AN HOUR TO GO! ?
I just want to say thank you to everyone here, for all the support and love you've shown this project over the last year. It's come so far in such a short time, and it's all thanks to you lovely humans. <3
Here's a quick summary post, for anyone who's just getting caught up to what's going on:
Kickstarter
Hello everyone! It’s been a long time coming, but the Winter One Kickstarter is finally happening, and goes live in just a few hours!!!
COUNTDOWN TO LAUNCH IS HERE
Get there early for a limited time price! ❄. * ・ 。゚. * ☆━ヘ(>_<)/
FOR PRICING INFORMATION SCROLL TO THE BOTTOM
Winter One v11 — (Kickstarter Version) Changelogs!!!
1. Slight Volume Increase from 15.4L >> 15.6L
2. Added Dual 280mm Radiators (Including the HWL GTS280!)
3. Added 30mm Radiator + 25mm Fan Support! (56.5mm *total* fan+rad clearance!)
3. Increased GPU Length to 315mm (3090 FE is now Supported!)
4. Increased CPU Cooler Height to 70mm
5. Created a Pump Bracket for mounting liquid cooling pumps
6. Switched Fully Machined Exterior (better tolerances & finish)
7. Redesigned Side Panels for another 4% cooling capacity
8. Added mounting support for AquaComputer Quadro (micro fan/pump controller)
9. All Beta Feedback Incorporated (lots of little changes, too many to list)
I'll be making a more detailed post with v11 changes this weekend, and will go into a lot more detail.
Thermal Testing
Winter One's thermals are incredible. This sort of cooling in an SFFPC case is unheard of, and the results are pretty jaw dropping.
Winter One Air-cooled:
* with fans at 900rpm in bottom >> top flow, a 2080Ti and 3800X ran 2-3ºC *cooler* **than an open air test bench**
* with a Raijintek Morpehus on a GTX 1080, **using case fans *only*** achieved, 73ºC temps on the GPU.
* Airflow is so strong it overwhelms some GPU coolers that exhaust out of the long edge of the card (like the 2080Ti FE). Turn fan RPMs *Down* (from 1300 >> 900) to achieve 4-6ºC better temps
Winter One Liquid-cooled:
* v10 Beta Unit with [Dual 240mm Magicool G2 Radiators, and Swiftech MCP50X pump]()
* 3900X + 2080Ti, running Prime95+FurMark *at the same time*.
* 3900X at 75ºC, and the 2080ti at 52ºC
* Water held steady at 42ºC (+12ºC vs ambient)
* Fans were at 1200rpm, and system was *utterly* silent.
* This was during a heatwave — Ambient Temps were a blistering 30ºC (85ºF)
* Performance Panels + Dual 280’s is expected to improve cooling by another 30%
All Thermal Testing was done with Beta (v10) Units and Solid Panels.
Acoustic Optimization:
Measurements Taken with a UMIK-1 Reference Mic on v10 Beta
* Below 26dBa at 1200 rpm (NF A14)
* Peaks spread at roughly 200, 400, and 800Hz due to optimization
* Nothing above 1.2Khz is louder than 22dBa (keeps high pitched noise away)
* Measurement distance was 20cm
Airflow
I thought you'd find these interesting, as you can get a really nice look at the incredible airflow of Winter One
Airflow in with Solid Panels (Bottom -> Top)
Airflow with Performance Panels (Side Intake -> Bottom / Top Exhaust)
See What Beta Testers Are Saying About Winter One:
Below are two reviews from Beta Testers of Winter One
These users have been building in an early-access version of Winter One v10, and they loved it so far.
Performance is where Winter One Shines… both sets of radiator fans run with almost completely unrestricted intakes meaning no turbulence, no chop, and almost no noise whatsoever no matter how fast the fans are running. In general gaming and ML scenarios, the system is inaudible… Dead silence vs. overclocking in an SFF case with no-compromise hardware isn’t going to be a compromise and I cannot wait to build in it (again)!
@Qzrx Link to Full Review
It's a damn good case, and the moon is made of machined aluminum cheese.
@gelbetron Link to Full Review
Winter One Website Update
A *lot* of information went live on the [Winter One Website](http://www.winterdesign.co) over the last few days. Be sure to check it out:
* Finalized Dimensions for Winter One
* Part Compatibility Information
* Build Photos
* Airflow, Design, Materials, Thermals, and Acoustic Optimization Section
* Kickstarter Countdown Page!!!
Augmented Reality Preview of Winter One
More Pictures of Winter One
Gorgeous Finish
Cork-Padded Feet
Machined Top Panel
Next to a Monitor and Keyboard
## Part Compatibility
Pricing and Configurations
