Just completed my itx build. I am a creator/photo editor/real estate photographer and this is going to be my work pc. Its been up and running for about a week now. Slowly been transferring files from my older build to the new build, Lr, Ps, etc... As long as I stay offline everything is working just fine, but as soon as I go on line I have issues. I can have 1 or 2 tabs open surfing the web then when I go to perform a task such as signing out of Amazon or opening up another tab my screen freezes up, can't even move my mouse pointer. Most times after a few moments it restarts & I have to sign back in, other times I have to unplug my pc and repower. Everything is up to date (Chrome, Windows 11, & my GPU Studio Driver) and like I said it only happens when on line. I've been transferring files, presets in Lr, actions in Ps, and cleaning out old unwanted files, pc is on for 4-5 hrs with no issue until I go online, I use Chrome as my web browser. I read that it happens in Edge as well but I don't use Edge.
My temps are good, at idle 28C, when under load, heavy Ps editing with multiple layers (4-5 images) temps run 55C, as soon as I finish and merge files and save back into Lr temps drop down to idle temps. I did a clean brand new Windows 11 Home installation, (not a Windows 10 update), via usb, purchased from NewEgg. Was not a copy, all components are new.
New PC Specs:
ASUS B660i
i7-12700k unlocked
EVGA GeForce GTX 1650 Super
OS Windows 11 Home
Corsair Dominator Platinum DDR5 64GB 5200mhz
Corsair H100i Elite AIO
Corsair PSU SF750
'C' Drive Samsung 980 SSD 1TB PCIe 4.0 NVME M.2
I use Microsoft OneDrive so I contacted them looking for help. I find it funny that they make me check all the boxes with cars in it so they don't talk to a robot then the want me to talk to a robot (AI at times seems worthless). During the chat I just picked up on things that made me think it just didn't understand. Told me I needed to do a Windows 11 In-Place upgrade to fix the issue. I googled it and saw on line posts with similar issues, saw some videos on youtube and it seems to be a re-install of Windows 11. Is it or is there something new added to it?
I question this fix because why is this not just incorporated into the Windows 11 updates that your pc asks you to perform, just doesn't make sense to me. Why are they calling it an In-Place upgrade instead of telling me to re-install Windows 11? Most were issues that people were experiencing doing a Windows 10 update to Windows 11. Remember this was a clean brand new Windows 11 Home installation & my ASUS B660i is Windows 10 & 11 compatible.
Is anyone having the same problem? If so what did you do to correct? If you did do the Windows 11 In-Place upgrade did it work? As of now I have to surf the web and create this post on my older pc in fear that I'll never be able to finish the post using the new one before it freezes up. So in short, using the old one for the web & using the new one for photo editing.
Just not sure if Mr. Robot from Microsoft has the right answer or not. Sure would like some help here. Thanks for reading.
New PC Specs:
ASUS B660i
i7-12700k unlocked
OS Windows 11 Home
Corsair PSU SF750
