Discussion A300M-STX Windows 11
guitarmanga
Hi All.
Was wondering if the A300M-STX will work with the new release of Windows 11?
I downloaded their WindowsPCHealthCheck tool, and it said This PC will not run Windows 11.
Trusted Platform Module (TPM)?
Any ideas?
Thanks in advance.
5,567
4,778
Enable the "fTPM" option in the BIOS, it should be somewhere around the CPU options. It enables the TPM functionality in the firmware (the "f" in fTPM). I've been using it since Ryzen 1st gen with great success.
Just one tip most people forget: with every BIOS update that also updates the AGESA, you will have the fTPM reset. Meaning you need to suspend BitLocker right before updating the BIOS.
Reactions: REVOCCASES
