Cooling Why is it not recommended to overclock with a low profile cooler?
Damascus
553
395
The cooler has low mass and very few heat pipes, it simply isn't good enough for most overclocked CPU's
loader963
662
569
That big shuriken could handle a bit of oc if you delidded. I had one with a 6700k ( not delidded) at 4.5 in a silverstone rvz02. But I know kaby runs a bit warmer than sky lake. But yeah, at these sizes they can only handle so much heat. What case are you using?
ng4ever
ng4ever
Could you mount a 120x25mm fan to the shuriken? That would help quite a bit I’d imagine.
I did. Actually a 140 or 150x25mm fan just earlier!
It has mount holes for 120mm! So it worked!
Not sure if it helped a lot because I forgot what temps were before with the 120x15mm fan lol.
I know in Prime95 2.6.6 it only went up to 81C
loader963
662
569
Well if that’s it in benchmarks, surely you are 15C cooler in normal uses. Why not run a mild oc and see how it does. If you have hwinfo64 or another sensor program you can monitor your temps and make sure you are safe.
