Isn't Asetek the best pump maker though? They hold most of the patents and IP I thought. I am currently using mine off of their 645LT (92mm AIO) and have it going to a 240mm rad and 1080ti with EK block. No problems at all, been running it for years, and 100% silent.
So if anyone is looking for a super compact setup I highly recommend it, not to mention saves a boatload of money.
The only thing they're best at is holding and enforcing said patents and ip...
They only started improving their pump design in recent years because the competition started to get creative with working around their patents.
Their pumps up to
gen 5 gen 6 were garbage, and barely had enough flow to to keep their own finstack working optimally, without any margin for future restrictions due to wear let alone modifications.
Gen 5 and especially Gen 6 are much better but not even close to the pumps found on the likes or arctic and EK's latest units.
Edit: seems like I was giving them too much credit, gen 5 was garbage too.
For reference, this was basically the "best" the could come up with untill gen 6:
These are the EK, Artic and Asetek gen 6 impellers(if you can't really picture the size difference their diameter is basically the same as the entire internal diameter of the gen 4-5 pump... pictured above):
