Cooling Using BeQuiet! SilentLoop pump/block for a custom loop?
Tazpr
553
429
Hey all,
I'm just curious if anyone has experience with the BeQuiet! SilentLoop series of AIO's and most notably the pump/block combo on it.
Planning a loop for my new system and not sure on the quality of the unit compared to a DDC.
I have an Apogee drive 2, but it uses the old super loud DDC so it's not ideal from a noise perspective unless I swap it out - which costs about the same as the BeQuiet unit, rad, fans and all so I don't think this is worth it.
Thoughts or experience with these?
Cheers,
Tazpr
Tazpr
553
429
Are you planning on cooling a GPU in this loop or just the CPU? Also what size Radiator?
So at first the loop will be CPU only, because it's a custom case I will just need to do final measurements when I receive the case if a slim rad+fan will fit in the bottom, which I am confident it will, but need to double check.
The main radiator is a 120mm radiator.
I have done some extra digging and it looks like the SilentLoop uses an Alphacool DC-LT pump with a nickel plated copper cooling plate which is a good start, although how it compares to an Apogee Drive II with a DDC MX pump is unknown.
fergunat000
(Test Fit image) this is an image of the recent loop that i downsized, but it doesn't have the processor or ram installed.
So you should be more than fine with the Alphacool DC-LT for a CPU loop, I used one in a test loop (for a future build that may use a gpu too, very slow progress). With this triple 50mm radiator I can get my i5 4690k to 60 C at stock. The biggest thing is getting the air bubbles out so it runs quite.
fergunat000
DC-LT 3600 is the more powerful pump (look at the pressure head) that might be able to run a GPU in your loop.
DC-LT 2600 Ultra low noise is probably what is being used in the Silent loop block (also the one used in my Alphacool Eisbaer LT (Solo)) and I question its capability to have enough pressure head to more through a GPU block along with a CPU loop.
Apogee Drive 2 has about twice the pressure head of the 3600.
The pressure head is the biggest indicator of how many components you can have in a loop each cooling block, rad., and even bend with have a pressure drop associated with it.
Jays2cents did a video using a DC-lt in a Silent loop block, he was trying to push water through a CPU, GPU, a 2 - 240mm radiators. The pump wasn't able to perform cause the 2 - 240 rads were too much.
Edit: added quote
