Which case should I get?
kz1343
I am planning to build a portable machine that I can take with me for LANs and trips overseas. The case needs to fit a SFX-L PSU, 122mm Graphics Card, A full size HDD and SSD, and a mini ITX board with at least 60mm clearance, What would reccomendation be baased on these specs?
7,411
Really depends on your budget. Something like a Silverstone Raven, Sugo SG13, etc could work. also, 122mm GPU - that's tiny - are you sure that's the length of your card?
