Hey I'm new!
I already have an ITX-Build. I'm using a COUGAR QBX case.
I was OK with it but temperature is not good in my opinion. Warm air doesn't get out good enough. The top has a 120 exauste fan but it's covered by the case itself very much so it's a joke!
Which case should I buy instead? I will put it on my table so I'm a bit limited in space. I can go up to , let's say, 25cm in width I think.
I don't have high end hardware. I'm using an Intel Core i5 4th gen, GTX 1060, SFX PSU, 16 GB RAM, 1x 2,5" ssd, 1x 3,5" hdd.
Which case you recommend? It's important that I can buy it in europe and it's UNDER 100€. So NCASE is not a solution.
What do you think about the RAIJINTEK METIS PLUS ? Compared to the Fractal Design Core 500 and Corsair Air 240 ?
