I was debating the exact same thing. Between the same cases. I’m trying to build my first SFF mini iTX pc, I’m tired of my huge oc taking up tons of space. After a lot of research I’ve decided to go with the new Geeek A60 case. It’s the same size as the Ghost S1 with the large top hat so it supports a 240mm radiator for cooling which I absolutely want. The problem with the Louqe Ghost is, simply put, I don’t want to wait 6 months to get one. Some of the first project backers are still waiting to receive some of the first batch from months ago. Louqe also is horrible at communication. The Dan A4 is the next option but doesn’t support liquid cooling (aside from the hard to find and very limited, soon to be discontinued 92mm AIO). Yes, the Dan C4 is coming out sometime but that could be late next year and I’m sure it’ll cost around $300. I came across a company called Geeek that makes a ghost/ Dan A4 size case called the A50. It’s a aluminum frame with acrylic panels. It’s also shipped IKEA style so you have to assemble it (I’m perfectly fine with that, also it allows the company to charge less. Geeek is releasing a new case called the A60 in the next week or so and it will accommodate a full 240mm AIO and uses the same layout as the Dan and Louqe cases. Will come in matte black with clear side panels
