Memory Very low profile DDR4 ram
A--E
Got the ram modules
And they are...
edit1: 3000Mhz at 1.4V stable on my Ryzen 5 1600 system. CL16
edit2: nope
edit3: 3066Mhz 1.4V CL 16 with lower (3.9 instead of 4.0) CPU clock.
edit4: 3200Mhz and stable
edit5: interesting fact. a-data memory seems to be unable to change timings, voltage and inherits these from my previous module (16-17-17) however as I change timings in BIOS it does nothing but the memory seems to work correctly.
edit6: part # AD4X266638G19-BP and base timings (from a-data docs pdf) are 19-19-19-43. mine works with 16-17-17-39
so I can conclude that it is exceptional good for its price.
Demon Boy Jr
86
117
Got the ram modules
And they are...
Still waiting on mine, hopefully I dont get the wrong dimms lol. Mine says it's just cleared customs since the 22nd
scatterforce
411
325
Anyone tried the Kingston VLP rams? Seems to have slightly better timings than the ADATA.
The Kingston Ram is ECC. In my build, I bought the RAM before the motherboard and wanted to ensure compatibility. Most AMD boards work with ECC ram, but most intel (all consumer?) boards do not.
edit: apparently, Kingston does make VLP non-ECC ram. Good to know.
teodoro
109
77
Am I reading that aliexpress listing correctly that it really is a dice roll as to whether you’ll get VLP or standard height dimms?
NinoPecorino
Tweezer Squeezer
506
515
yes. they seem to usually be the vlp ones, but it is a gamble. i'd suggest using taobao through superbuy.
Donut
56
35
I have them in a build with an 8700T - the CL19 2667 ones. They worked great out of the box, and I have no complaints. Purchasing from Kingston was nice as well.
I haven't done any RAM overclocking (I have an H370 board, so I don't even know if it's possible for me to do so), and I haven't done any benchmarking. Don't really know how they stack up in terms of performance. I can try to run some benchmarks if you have any software suggestions that work in Ubuntu.
HFoletto
There are the Crucial, even if ECC they works perfectly in my Z390 with no issue
That's true, however I had trouble finding them for sale.
Also, I was looking to avoid ECC because I'm unsure if I'm going to use intel or ryzen, so better have some standard memory.
fabio
1,885
4,325
I understand. I was only saying that not matter what they will work on Intel or Ryzen CPU :)
And you can buy directly from Crucial!
https://eu.crucial.com/eur/en/ct16g4xfd8266
