Cooling Using liquid propane for SFF cooling?
As far as traditional gaming, though… I am currently working on a new PC that people might find pretty interesting. I have experimented with liquid nitrogen cooling in the past, but it is a huge pain to work with in any kind of daily use, and can also be dangerous. My new project is a very small super-powerful PC with no heatsinks and no fans - it is cooled by liquid propane, boiled into gaseous propane in an expansion block. From there, I can either compress back into a tank under high pressure, or vent out of a burner nozzle for supercooling to subzero temps. If I had more time, I would vent the propane to a small turbine generator hooked up to the PSU, but I can’t justify that kind of work right now.
https://www.reddit.com/r/pcmasterra...luckey_founder_of_oculus_and_designer/cytl8lz
This is from Palmer Luckey's (founder of Oculus) AMA on reddit.
Palmer is a smart dude so I figure he's done his research and determined it was feasible, at least in theory. Anyone have thoughts on this?
Budget is no longer an issue for him so I bet he's doing it because it's a challenge more than anything.
EdZ
Virtual Realist
May 11, 2015
1,578
2,107
Propane boils at -42°C (at ambient pressure), so as long as you have a mighty condenser/chiller, you can use it as a phase-change fluid just fine. An explosive phase-change fluid, but most phase-change fluids are rather unpleasant to be exposed to anyway.
BirdofPrey
Standards Guru
Sep 3, 2015
797
493
In those cases, the propane is burned to provide a heat source for an absorption refrigerator.
It's not actually used itself as a refrigerant.
