My bad full name is Dan C4-sfx and here are specs
Specification
Case Dimensions (H x W x D): 239,8 x 127,3 x 322,8mm, 9.85L
Overall Dimensions: 250 x 127,3 x 322,8mm (including case feets)
Weight: ??? Kg
Graphic cards support: Dual-Slot and 2.5 Slot GPU up to 295mm length
Motherboard support: Mini-ITX
Power Supply support: SFX, SFX-L
CPU Heatsink support: Up to 62mm height
Water cooling support: 240mm AIO
· radiator thickness 38mm with 2x 16mm thick fans
· radiator thickness 30mm with 2x 25mm thick fans
· radiator thickness 27mm with 2x 25m thick fans
· radiator thickness 22mm with 2x 25mm thick fans
Drives: 3 x 2.5" HDD/SSD
Front ports: 1 x USB 3.0 Type-A & 1x Type-C (internal 20pin plug), 1x Microphone, 1x Line-Out
Power button: Premium-grade button
Material: 1.5mm aluminum (outer parts), 1.5mm aluminum (inner parts)
Side panels: Easily clipp able with Lian Li Push Pin technology
Colors: Anodized sand blasted black or silver exterior, matte black painted interior
Risercard: Includes PCIe 16x hard riser
Price tag: 160-180€
