Stalled [Update: 22-02-2021 - V1.1 Revised internals] LytCase Rogue: 8.9L Sandwich style case with 240mm AIO support.
Keep sub 9L volume or exceed 9L for better overall compatibility?
  • Keep sub 9L with 2lot configuration and better cpu block clearance
    Votes: 0 0.0%
  • Keep aub 9L with 2.5slot and limited cpu block clearance
    Votes: 11 40.7%
  • Exceed 9L only to the point where a 3 slot card can fit
    Votes: 11 40.7%
  • Go full-on - 3slot, standard fans, cpu block clearance etc.
    Votes: 5 18.5%
  • Total voters
    27
  • Poll closed .
Tazpr
552
426
Australia
Hey All,
Updated the OP with pics of the new sample with 2.5slot and rearranged internals.
Looks absolutely sensational Lytnin, really nice finish too! I think giving that 2.5 slot support is going to be a major advantage for taller fittings or cards like EVGA's XC3 models.
What are your next steps from here? Are you at a point where you have a case you're happy with and may look towards funding?
Lytnin
97
200
Bahrain
Just need to figure out the quality control with them (just to make sure the pins align correctly, and paint finish is done right)
But im pretty much done... One thing im starting to consider is to remove the 2.5inch drive support completely, as it fits, but makes your life harder in regards to psu cable routing and mounting the psu bracket. So i'd like all you guys' input on that...
Once i finalize the costing with them now, ill be ready to start looking for funding.
threestripevida
277
466
in my opinion it’s nice to have a place to mount a 2.5 inch drive. If there’s one thing I’ve learned from being on this forum for a few years and seeing peoples build tho, is that people will find a place to put the drive on their own if they really need it.
Tazpr
552
426
Australia
Hey guys, just wanted to update you all... Unfortunately the project has faced a lot of issues in terms of logistics. So will have to rethink the whole process. I appreciate all your support with me so far.
Sorry to hear that Lyt, appreciate the update and hopefully we still get a chance to support this project into fruition.
