Hi,
I quickly searched the forum but didn't find an obvious solution to the following problem:
Being able to mount fans of different sizes (say 120mm or 140mm) on the same panel, without special mounting holes for each. And expanding that to 240mm or 280mm radiators.
By "no special mounting holes" I mean the same grid of holes on the panel that allow air to pass through can provide mounting holes for the fans.
A tentative solution:
Mess with the tolerance of the panel holes so that you can fit both the 105 and the 124.5 hole pitches on the same grid. Making this work for two fans in a row (i.e. for use with a radiator) is a bit less trivial because 120 fans have 7.5mm "margin" and 140mm fans have 7.75mm.
Edits:
Several good solutions came up in this thread.
I am working in one of them now (first prototype with dimensions in this post, new dimensions here)
Edits:
