Think_Micro v3
7,424
Time for a personal project.
A long time ago, I build a PC I called Think_micro. It was a little 2.8L scratchbuild that I never really finished.
After rolling ATX for too long (woops) It's time to go small again.
This build/mod will be using the Jonsbo C2 - https://smallformfactor.net/other/jonsbo-c2-sitting-in-the-middle
The motherboard (https://smallformfactor.net/reviews/motherboards/ecs-a960m-mv-m-dtx-or-is-it) and the cooler I intend to use:
(I may not run all 3 fans though!)
A view of some of the hardware in the case and you can see the major issue:
Time to make it fit.
Cooler in, roof off:
Ooh, it doesn't poke too far up
Front of the roof won't mount down flat (evidenced by the rear shown here sticking up)
This'll work. It also has the advantage of adding a vent to the top of the chassis, something it sorely needed.
That's all for now. I still need to:
-find/buy a GPU (GT210 that is currently in the case is insufficient)
-shorter SATA cables
-a SSD
-a DC-DC power supply (picopsu or another variant)
-window mod
-sleeve wires
5,943
4,952
Interesting project ! That Jonsbo will not be recognizable when you're done I'd reckon !
7,424
Yes, via a flexible riser down to the bottom expansion slot :)
iFreilicht
FlexATX Authority
Feb 28, 2015
3,243
2,361
freilite.com
Don't you think you could fit an SFX PSU in there by removing its fan and ducting the CPU cooler airflow through it? Would make the complete product much more interesting. You could also trimm the CPU cooler at the top to make the top panel fit like it previously did.
Other than that, interesting project, will make sure to follow.
7,424
Not nearly enough room for a SFX psu even without the fan.
I like the way the top pops up- the case needs more ventilation with a 125w cpu and possibly a similar wattage gpu to come. I will however accentuate the gap with lighting- 3mm of room there. Perfect gap for some frosted acrylic :) I have a PSU option that is even more interesting than a modified sfx unit, watch this space
NFSxperts
112
53
Nice idea with the vent at the top. I'm going try that with mine as well. This case really needs more ventilation.
7,424
It's easy, they even include the rubber spacers in the stock setup :p Just be careful not to strip the screw heads
LooseNeutral
LOSIAS
Jul 3, 2015
46
23
You've had "Think Micro" long as I think I've known you man. I do believe you did name a project this a few years ago. Matters not. Good to see you build. I'll say it loud and I'll say it proud.. Confu was the first guy who ever welcomed me into the modding scene. got over the admiration of it all, sadly. But found so many friends in this scene because of an answer to a newbs questions. Confu was there for me. This is how you build. Trust. Oh we, had some bruhahas. So what, that's what friends do. When you really care, are a friend. Why I'm loving seeing my friend build, he's been pretty damn good at helping others with designs. helping when and where he could. YOu're a rare breed my friend, and I say FRIEND with pride and mean it. rare thing in this life these days. I value. never take advatage of. Build this shit John. Own it like the dreams you've had for years. I don't care how long it takes. more time I may have to call you friend befor I go away from here. Not planning on it anytime soon lol.
Reactions: confusis
NFSxperts
112
53
Any updates?
I used thinner spacers so the rigidity isn't compromised too much.
7,424
Nice! No updates as yet - still decided on cooling and power supply solutions. Cooling being the major - 125w of CPU and 110W of GPU to vent!
jØrd
S̳C̳S̳I̳ ̳f̳o̳r̳ ̳l̳i̳f̳e̳
sudocide.dev
LOSIAS
Jul 19, 2015
818
1,359
Dual block closed loop?
7,424
It's an option, especially with the new Silverstone units. Depends on price though
NFSxperts
112
53
I thought the purpose of this buildlog was to use the D15 for cpu cooling?
I think the only way to fit all that in there is to use a 250w-300w dc-dc power board, but those are expensive.
7,424
Even with the D15 I was struggling to keep everything cool - just not enough airflow without having ear-splitting fan noise.
I am regrouping with another chassis plan :)
NFSxperts
112
53
Awww, I was looking forward to seeing what you could do with this case.
This case might only suitable for systems with no gpu.
Last thought, would the D15 fit if it was mounted horizontally?
7,424
possibly - although with AMD sockets i'm prevented from doing that
The case will be reused as a silent HTPC so there is a future for it :)
7,424
I have new plans and this project will indeed be continued.. with a new direction.
7,424
A short story:
A while back, a friend of mine was designing a crazy production spec SFF chassis. It never eventuated (due to many factors), and he handed over the prototype coolers to me.
Prototype coolers?
Yup. One for CPU and one for GPU. Water.
As you can see above, a dual 80mm Black Ice Micro v2 rad would fit nicely!
(I considered a single 140mm rad at the bottom of the chassis, but rad+fan = no room for GPU even with the cooling solution)
Reactions: jØrd
