It's done: The all-AMD gaming PC at the ragged edge of miniaturization with semi-custom and off-the-shelf parts. Despite the aftereffects of the mining boom, 2018 is an exciting time to be building. AMD has risen (Ryzen?) from the ashes, semiconductors are getting smaller, cooling technology is better than ever, and 2019 is going to be awesome with Zen 2 and the eventual release of Navi.
SPECS:
Asrock B450 ITX mobo
Ryzen 5 1600
Sapphire Radeon R9 Nano 4GB HBM
8GB Samsung DDR4 @ 2400
XPG SX8200 480 GB NVME SSD
HGST 1TB HDD
Misc specs:
CustomMOD Flex Mini 4.5-liter case
Seasonic SUG Gold 300W PSU (Noctua fan swap, custom painted)
Anne Pro 60% Bluetooth Mechanical Keyboard
random Korean gaming mouse
Noctua NH-L9 AM4 cooler
Thermal Grizzly Kryonaut thermal paste
Windows 10 and AMD StoreMI
This is a work in progress: Ideally, the final product will boast a gray & orange-red Ryzen color scheme. Case: gray; Mobo and CPU cooler: gray; PSU: orange; sleeved cables: gray & orange-red. Once this is done, acrylic side panels with a laser-cut Zen logo would be killer. Thoughts or suggestions on how to improve this idea?
Full imgur album:
Comments on the build and quality of the CustomMOD case:
Overall the case quality is quite good. The side panels fit well, the front I/O port lines up, the powder coat is perfectly done. My main complaints all seem to involve screws and screw holes.
When in-game, the entire computer will sometimes go black and reset/reboot. I think this is a power problem, as the R9 may be overloading the 300W PSU. Undervolting the GPU seems to fix the problem.
In addition, there is a persistent screen flicker. The screen flashes for an instant once every two seconds, even right after POSTing. Does not flicker on the desktop or in most games, but does in some. Cycling to windowed mode then fullscreen mode seems to stop the symptoms until the next reboot. Symptoms and attempted solutions are beyond the scope of this post, maybe I'll post them somewhere else.
1080p Benchmark results: COMING SOON
Heaven
Cinebench R15
Firestrike
Novabench
Realbench
Here is as good a place as any to mention AMD's StoreMI tech. I feel it deserves a shout-out, as not many people seem aware of its utility. Basically, it combines an SSD and a larger, cheaper HDD, combined them into one JBOD, and intelligently moves your most used files to the SSD. It's the main reason I sprung for the B450 mobo, as StoreMI is only on 400-series chipsets. It was absolutely worth it. Windows boots in 9 seconds and once I've played a game a few times, its loading times drop measurably.
Thermals at stock clocks and voltages: COMING SOON
CPU stabilizes at about 62C in Prime95 Mixed
GPU hovers around 70 in demanding titles
Future plans:
SPECS:
Ryzen 5 1600
HGST 1TB HDD
Misc specs:
Back in April/May I set out to downsize my SFF gaming rig. At the time I was using the Jonsbo/Cooltek C2, a 12-liter micro ATX case with ATX PSU slot. Even though it qualified as SFF, I knew it could be smaller. Cases as small as 6 or 7 liters can fit an SFX PSU and full-size GPU. Then I discovered the S4 Mini, Chopin, Modivio xCase S, but these all required a compromise, either in the form of an external power brick or iGPU. Eventually, the ZS-A4m and the CustomMOD Flex Mini emerged as competing no-compromise options: internal PSU and discrete GPU in just 4.5 liters. In the end the Flex Mini won out because CustomMOD has a presence here, the case was more customizable, and a PCIe riser and Flex PSU could be ordered all at the same time.
Full imgur album:
- 2.5" HDD was very difficult to install because of front I/O cable. Moving mounting holes 10-15mm toward rear would substantially help installation.
- Bottom feet mounting screws too short. Sometimes only 1-2 screw threads penetrate base plate.
- Thumb-screws and cleaner tap&die process on GPU bracket mount would be nice.
- Finally, case screws seem prone to stripping. It's possible my screwdriver was too small but the metal seemed soft.
- Not really a gripe, just need to point out that if you choose a custom powder coat color, as I did, you will have to self-thread the front-mounted power switch because the powder coat takes a few tenths of a mm from the hole diameter.
Heaven
Cinebench R15
Firestrike
Novabench
Realbench
Future plans:
- Get custom-sleeved cables for PSU, HDD
- Noctua told me in an email they'll be releasing a black NF-A9x14 sometime in 2019. Will swap current CPU fan when that happens.
- GPU fan mod: I want to emulate this Nano fan mod with a black NF-A9x14
- Maybe an acrylic side panel and RGB lighting strip to show off the Zen color scheme
