Initial build: https://smallformfactor.net/forum/threads/i-think-i-found-a-little-gem-realan-e-i7.6175/
New build:
Parts list:
CPU: AMD Ryzen 9 3950X
Motherboard: ASUS Crosshair VIII Impact
RAM: G. Skill Trident NEO 2x16GB (Hynix)
GPU: ASUS GTX 1650 LP
SSD: 2x Corsair MP510 1.92TB M.2
PSU: G-Unique ArchDaemon 400W plug-in, with custom 400W Dell external brick
Cooler: Cryorig C1 with Noctua NF-A12x15
Fans: 2x 80x25mm, 1x 80x15mm, 2x 60x20mm
You might ask why I had to go with the Crosshair VIII Impact. I didn't. However, this board has top of the line components, and the best VRM cooling among ITX-width AM4 motherboards. In a small enclosure, I wanted to make sure I wouldn't have any heat-related reliability issues. Plus, where I am now, this board retails for only $60 more than the ASUS X570-I...
On the non-functional side, I am an SFF enthusiast and I like putting big hardware where all evidence suggests they shouldn't go
Why the 3950X? Until 3950X's showed up and were reviewed, I was pretty much sure there was no way I could sufficiently cool them. But reviews, especially Optimum Tech (thanks bro ), proved that this beast is something special, and it works very well even with quite measly cooling. I trusted my Cryorig C1 would do a better job than the Noctua NH-L12s, especially with the Noctua NF-A12x15 fan I got for it, and I wasn't disappointed.
A side note on the Cryorig C1... if you look closely, you'll see that the heatsink is actually designed to work best with a 120mm fan. The dimensions are that it's 140mm wide, but the top heatsink surface is 120x120. That is why I purchased the 1850-RPM 120x15mm Noctua fan instead of the original 1350-RPM 140x13mm Cryorig fan. The resulting air pressure that goes into the heatsink is much better but I'll do some comparison tests later...
In this tiny 5.8 liter case, the 3950X performs like the beast it is. I haven't done any extensive benchmarking yet but for starters, Cinebench 20: SC 529, MC 9593!
The power statistics are that 3950X draws about 12% more power than the 1800X I retired, that's about 145W (CPU only) in CB, which is higher than stock since I have the 1900 FCLK and PBO+200 enabled.
Thanks for looking! Any questions, let me know below...
New build:
Parts list:
