ignsvn
By Toutatis!
1,735
1,683
Whoops! Jumped the gun and thought it was a new set so I submitted another preorder thingy.
LOL leave it there, it'll help to reach 50 sooner.
Also, there's nothing wrong to own more than 1 MI-6 :)
Revenant
Revenant Tech
1,741
2,833
When it gets to 49 I might end up buying a third.
Fire...Can you send one to Optimum Tech? He seems to specialize in SFF and it might drum up some interest.
Revenant
Revenant Tech
1,741
2,833
So I just wanted to take a minute and thank Fire again for making an awesome case. A friend was over and we were gaming. When he realized I was playing BFV on my MI6 and not the Sliger Cerberus X next to it his jaw dropped. He said he thought the MI6 was an external hard drive cage because it was so small. He's thinking of preordering one now. ^_^
ignsvn
By Toutatis!
1,735
1,683
Awesome
firewolfy
424
836
Unfortunately, I don't have a case to send him.
firewolfy
424
836
LOL. That is fun to hear, man.
firewolfy
424
836
hello, i really like this case, would you be able to ship one to egypt if i pre-order one on the next patch ?
Thanks.
I don't think shipping a case to Egypt is an issue at all.
If you'd like to pre-order that would be great. Just so you know, since the pre-orders haven't reached enough to kick off a new batch run, I'm taking a wake and see approach on when or if a new batch can be made. Thanks, -F
ignsvn
By Toutatis!
1,735
1,683
Thanks.
You may want to fill in the pre-order list just like many of us here, so it'll reach certain minimum number to start production.
leifeinar
41
Question, is there room for a normal intake 92mm fan if I go for the No Front I/O option? not a fan of slim fans :) or do i really need one? planing to undervollt, both cpu/gpu
pre orders are at 47 by 12 of sept. not icluding mine.
Reactions: ignsvn
Revenant
Revenant Tech
1,741
2,833
Question, is there room for a normal intake 92mm fan if I go for the No Front I/O option? not a fan of slim fans or do i really need one? planing to undervollt, both cpu/gpu
The fan has been shown to improve temps on hard drives pretty substantially. If you're not running a 2.5 inch drive, you'll probably be ok.
I tried a 92x25mm fan but ran into problems with the power supply cables. I don't have front IO.
On a different note: My editing rig (MI-6) has become redundant since I have a the Cerberus with RTX card on the same desk attached to the same monitor. It was good fun to have both systems, but it's time for the MI-6 to move on.....TO BECOME AN AWESOME VR GAMING PC! I'll be moving it out to be front and center in the living room and making it into a VR and Gaming rig. It has a 1070 in it, but I think I'm going to upgrade it to a RTX 2070 Super whenever the ITX version comes out.
I have to admit though, the MI-6 is my favorite build. It's hard to part ways with it from my desk!
ignsvn
By Toutatis!
1,735
1,683
Don't forget that the fan thickness is also limited by the PSU connectors & cables.
firewolfy
424
836
I know others have responded, so I thought I'd chime in as well. It is a real challenge to fit a full 25mm tall fan in the bottom. Here is some info that I put up on the webpage inthe ANSWERS section:
What 92mm case fan will fit?
Well, in order of ease of installation:
  • A 13-16mm thick fan is easy. Plenty of room if you wish to raise the fan up from the case to reduce wind noise.
  • A 17-20mm thick fan is possible, you just might have to loosen the front I/O board (if you have one) to install it.
  • A 25mm fan is mostly impossible. You would need to check the PSU you plan to use for clearance. Also, a 25mm fan interferes with the front I/O board, and prevents mounting a HDD in the lower front location. So there is a way to get it in there, kind of.
Hope that helps.
firewolfy
424
836
Ok, a bit of good news.......
it looks like we might have enough pre-orders do another production batch. By my count we are at 54 cases or so.
A couple of things to figure out but looking promising:
  1. I would really want to get production done and shipped by the end of the year. It makes bookkeeping and taxes SO much easier. I have reached out to my sheet metal shop to verify they would be good to start in October. I should hear tomorrow.
  2. If it is feasible to start production in October, then I'd probably start taking payments now and run through the end of September to get to minimum 50 payments.
Anyway, thanks guys!
Revenant
Revenant Tech
1,741
2,833
I believe that this post deserves something special....
Reactions: rfarmer and ignsvn
