Hey all. I’ve been interested in SFF for a while now and coming over from large water-cooling systems that take up a lot of space on your desk and are made to draw attention has been a real breath of fresh air.
I recently built a PC in a Modivio xCase S and while I really enjoyed that chassis and I felt what they are doing with those was a great idea I started looking for something that fits in a bit more with my desktop. Something sleek, metallic and with some sharper edges. As a fan of the console style layout I first looked into the Skyreach and while I do love how that case looks, in the end I guess I was after something a bit more unique for me.
As I am active on Gury’s Discord server I saw him posting pictures of some cases he made for other clients there and became intrigued, so I reached out to him to ask if it’d be possible to design a console style case made to spec of the parts I planned to use;
Z370 ITX Motherboard of some variation
QN8J Engineering Sample (8700t equivalent)
Cryorig c7 cu
Gigabyte ITX card of less than 170mm (1070/1080 and now 2070 mini)
He agreed and we got underway planning. At first I requested a system with an external power brick using his archdaemon solution as I had good experience with it in the past, however shortly into the designing of the case he proposed the possibility of fitting the brick in the otherwise wasted space under the GPU.
As of yet I don’t have this case in hand, however I have many photos he has sent me throughout the manufacturing process which I’m eager to share. I’ll reserve two posts after this one for updates when I get new photos and the case in hand. So here goes.
Photos:
Please keep in mind these are just photos of a test fit of parts, the final chassis will also feature two USB-C ports on the front (the final spec of these ports is not fully decided yet)
I'm hoping I'll be able to finish this build of shortly after CNY so stay tuned for updates. I'd love to hear your comments on it
Also check out Gury's discord if you're after something similar, he's a really great guy and does some great work!
Cryorig c7 cu
Photos:
