Streacom FC10 with ATX mobo and PSU?
TutenStain
Hello,
I am putting together a build with a Streacom FC10 and their internal ZF240 PSU. According to their specifications if the PSU is installed, the case is "Limited to Micro-ATX or Mini-ITX Motherboard". I however managed to mount the PSU sideways, as in the picture (it should be flat if you read their manual I think). Wonder if in this configuration one could fit an ATX board? Does anyone know? Thanks.
6,591
One way to find out - try it, or measure it :) It does look like, at first glance, that there is threaded holes for ATX standoffs though.
