I've not really seen many DA2 builds using the glass panels, performance panels and fans blowing bottom to top in this case, so I'm going to have a go and see where I end up.
I've already hit the "breaking the acrylic panel" issue just testing how hard they are to remove ahead of upgrading to the performance panels. There is obvious a knack to it but I think it's a bit of a poor solution.
However my first proper snag is one that I've not seen documented so I thought I'd post up here for the benefit of others.
Corsair SF750 being attached to the Streacom PSU support plate, the power button shroud is touching creased edge of back plate (marked in red)
This means the PSU back plate is offset by about 1mm from SFX spec.
Spin the back-plate around (how I'd have it in my final build), and the cable tie prong part also touches the button surround (marked in red)
This is also offseting the back-plate and screw holes by about 1mm.
This means none of the holes align.
So I decided to file away the low part to just get the PSU fitted for testing. To remove the material on the area under the cable tie lug to get it fitted the right way would take a pillar drill or similar to just take away the part needed.
Now I try align the back plate. Success on the power switch.
But uh oh. None of the holes still line up. SFX requires two at one end, and the centre one at the opposite end.
I line up the Streacom DA2 back plate against the ATX > SFX adaptor plate from Corsair at one end. All lines up. Great, all to spec.
But the other end. Hmmm.
A quick measurement across the Streacom DA2 PSU back plate. This should be 113mm. It's actually 114mm (214mm - 100mm).
So right now it looks like the SF450, SF600 and SF750 won't fit the Streacom DA2 PSU back-plate properly because of the U section pushing into the space required at one side, and the U section running into the vertical cable tie support at the other side.
Even if you do adjust the back plate to give clearance, then the PSU back-plate still won't fit correctly because the SFX 113mm spec isn't adhered to, and is actually 114mm.
The end result is that you fit the PSU rotated to clear the power button, which also nicely aligns two of the holes.
However in my view this is completely unacceptable. I can accept that the SF series PSU have a unique power button position, but for Streacom to run outside the SFX spec for the spacing means you can't support the PSU straight or with 3 screws if you make suitable adjustments to the PSU back plate so it fits.
Quite frankly the 'Streacom' precision and high build quality image has totally gone for me now.
This is a bodge at the first step. This should be perfect.
Do I have a bad PSU back plate here? I'm sure I'd read someone else hadn't managed to get more than two screws in.
Anyhoo, using the brass risers I've now got plenty of room for a fan at the top once I get the performance panels. Once the mobo is in and I can get a feel for things, I think there will be room for two 12x25 up here, mounted as far to the side from the motherboard as possible.
Next job, fit the Strix B550-i, 3950x, noctua u9s, 64gb Corsair ram, 2tb mp600 ssd, my GTX1070 strix oc, and then get win10 on there and make sure everything is working as it should.
Then performance panels, glass panels, and two nfa12x25 on the bottom (if they'll fit in place of my Strix fans) running off the Strix fan headers... and hopefully two nfa12x25 at the top... then a few hours setting it all up in Speedfan or Argus Monitor so that in essence, the GPU and CPU suck in what they need, the top fans blow out just enough to keep a positive pressure position.
And a 3D printed duct from the back-panel intake onto the u9s fan haha, that seems critical in this case.
