I have an aquanaut atm and would be happy to compare the two at identical settings at some point
I would love to be a tester!Not ready to take deposits at this time. I will be looking for beta testers soon though
@Alloy Craft Count me in!Not ready to take deposits at this time. I will be looking for beta testers soon though.
Indeed, stainless sounds risky to me. I would actually prefer POM - looks good, lightweight, cheap and strong. And given how many times I've heard of nickel plating coming off in a loop, I would actually want bare copper for the base as well. I've run bare copper cold plates for years and years, and while they don't look pristine after a while, it doesn't matter whatsoever. Performance stays the same.@Alloy Craft Count me in!
Also, regarding metals, galvanic corrosion may be a concern with stainless steel depending on the grade of steel. Copper, brass, nickle plated copper/brass, POM, and clear acrylic would be the safest choices. I'd love a solid copper version myself.
Yes I am measuring flow. see my post with my testing results, I will post shortly. My last post has some errors, the barrow pump block had a bubble in the volute so it was under performing. The oring will force flow through the fin array and cause a larger pressure drop than a pump block that does not have one.Could you elaborate? You are measuring flow rate correct? And it seems like you are making some sort of assumption about o rings and the pressure drop? With the same pump and pump speed, if you have higher flow, it must be from lower pressure drop (less resistance). Maybe someone with a stronger physics background can correct me if I'm wrong here...
Thanks @Nouvolo I appreciate it. I have been following the Aquanauts progress for some time now. It looks like the Extreme edition will be a nice addition to the community. Cant wait for that Mr Crab version, lol.Hi @Alloy Craft , just dropping in to congratulate you on the great work you have done so far in this project.
This is pretty clever! I like it.From hence on I will refer to our block as the LOBO pump block, short for "low boy"
Do you have an idea of how much such a prototype would cost for a beta tester? I understand that the quoted price will not be final, but I would like to calculate my budget.LOBO pump block at a discount for testing.
As I wrote earlier, I am ready to become a beta tester. I have the following components if it's matter:
1. R9 5900x + Asus x570 Impact + RX 6900 XT RedDevil w / c + original Nouvolo Aquanaut + Barrow SPB17 + 2 * 280mm radiator
2. R3 4350G + Asrock B550M-ITX/ac (can also assemble a loop for cooling).
Throwing my name in the hat for beta testing once again.
I'm working with a 5600x and 3080 that would both be in the loop...built in a T1.
Have an OG Aquanaut here already and an Aquanaut Extreme ordered that I can compare to if it's helpful.
EmailedCost on the beta units would $50 each + shipping if you are outside the USA. A $50 deposit would be required as well. Deposit would be refunded when you post the requested information back in this thread. If you are interested please email me @ [email protected] for details.
HI @Fitchew, I just sent you and email.Hey, @Alloy Craft!
I wrote a letter regarding participation in the beta test, but I never received a response. If it is not difficult for you, could you answer whether I got into the beta testers group or not.
And by the way, the blocks looks amazing. I don't even know if they could have looked any better? What is the lack of quality here?
