Cooling Slimmest 240mm rad (like in the TD-02 Slim)
loader963
660
568
Looking for an extremely thin 240mm rad to play with on a littler project. Been looking and I have found a few 27.5-28mm thick ones but I saw that Silverstone is using a 22mm thick rad and Google is failing to find a commercial one for me. II'm guessing that there is some company online but I am tempted to just buy one and try to see if I could mod it for my use. Any of the experienced guys got a few tips for me?
Thestarkiller32
152
102
Material: Pure Aluminum
Connector: G1/4
Fan: 2*120*120mm fan
https://m.aliexpress.com/item/32812162539.html
Thats a Alu Rad, but if you use the EK Alu series, then it sould be good to go.
Reactions: loader963
7,135
There's always the option of buying the Silverstone closed loop cooler and using tubing connectors to connect it into your own loop :p
Unfortunately the thinnest rads I know of are the XSPC 30mm and EKWB 28mm units :(
