With unpainted there will be an option to select that you would like a custom color.
Dude that is insanely cool! Is there a site or something I can go to browse colors? Or will there be a selector with a set bank of colors to choose from?
Here you go. You'll even be able to add custom artwork and logos to the case.
Anyone knows the RAL value of "Noctua brown"?
Honestly - I think a full Noctua case would be amazing. That light beige color honestly isn't that bad, it's the brown that I think bothers people. But brown as the accent color looks pretty nice. My wife is an interior designer so I'll have to get her opinion ?I just did some rough testing using Chrome's color picker on a Noctua product photo - by no means a perfect method but since there's only a limited number of options it's probably close enough.
rgb.to/hex can show you the nearest RAL colour for any given HEX code which is quite helpful.
RAL 8012 is very close to the brown which is used on the vibration dampeners.
RAL 1015 is very close to the fan case.
I created this image to visualize the similarity of the colours.
The exact colour of the fan blades is harder to pin-point on the photos so I went with five random picks.
Personally I'd probably go with RAL 8012 and RAL 1015 but I'd to a little more research on the matter beforehand
Take this image, make white beige and the black accents (within the panel gaps) the dark brown.Front panel brown, side beige. Take the (Noctua) shit to a higher level lol
Color Name/Model | Pantone Code | (Closest ) RAL Classic Code |
Standard Models | ||
Fan | 483C | 3009 (Click for comparison) |
Frame | 2309C | 1015 (Click for comparison) |
Redux Models | ||
Fan | 431C | 7031 (Click for comparison) |
Frame | 427C | 7047 (Click for comparison) |
Chromax Models | ||
Red | 200C | No match found |
Blue | 19-4050 TPX | No match found |
Green | 18-6030 TPX | No match found |
Yellow | 108C | No match found |
I was bored... Ask and ye shall receive!
LOL I love it, it looks even better than I imagined.I was bored... Ask and ye shall receive!
