Hello guys, just a quick question if anyone has a solid info about it.
Can SM 550 accommodate any of these four fans? Wraith Spire, Wraith Prism, Noctua L9a-AM4 and Alpenfohn Blackridge. Thanks in advance.
From the specs page :Hello guys, just a quick question if anyone has a solid info about it.
- Coolers compatible with all side panel types (Unvented, Window, or Vented)
- Alpenföhn® Black Ridge (47mm)
- Noctua L9i/L9a
- Intel Boxed Cooler
- Cryorig C7 CU
- Cryorig C7
- Cooltek ITX30
- Phanteks PH-TC90LS
- RAIJINTEK Zelos
- Silverstone AR05
- Silverstone AR11
Hey all, but especially @KSliger and @Sligerjack,
There's a new Fractal Design AIO that was introduced this morning. I'm not sure when its shipping, but it's got a lot of things going for it.
Fractal Desgin S28+
It looks like this fixes the biggest issue with the older Celsius coolers, which is the tubes now come out of the side of the pump block, making it much easier to route in low-clearance cases like Sandwich cases. The older coolers were great, as they required no extra wiring like USB connections and such, they ran entirely off a single fan header (I think it needs to be at least a 1A header though), and it includes a fan hub with the wire going up the sleeve so your fan wiring is much cleaner too. This new one also has an RGB version if you're into that.
Looking at the radiator, it does not have the squared off corners like the Corsair radiators do, so hopefully it won't run into those problems. The pump block is also supposed to be only 45mm tall, so it shouldn't run into the issues the new NZXT X63 and Z63 coolers do with hitting the side panel. Is this something you guys could test, and maybe add to the list of recommended coolers if it works? I know you're also selling your own Asetek 280 units now so I dunno if it's high on your list to be testing other people's coolers![]()
I contacted PSLate Customs and now on their 6 week waiting list.
Any word from Level1Techs? Also I noticed that the Asetek 280mm AIO is no longer listed as an option on the SM580. Did this option get discontinued?Just checked the specs, looks good to me! I believe fractal use Asetek as their OEM, so everything should be work fine!
I'll drop a line over to Level1Techs and see if they can verify fit in the SM580 they have!
Based on my experience, you can place 645LT in both SM570 (with/without sliger 645LT bracket) or SM580 (without bracket with washers).Hi guys was just finalizing my order and was honestly torn between the sm570 and sm580, switching from a steck/ophion build. My current equipment is a 240mm evga cpu aio, 92mm asetek cpu aio, a 120mm asetek cpu aio, and a evga hybrid 1080ti ftw3 kit (120mm rad). If i do change the hybrid kit rad to a 240mm is it possible to fit that in the top or will the tubes get in and can you fit an asetek 92mm aio at the bottom of the sm570 or sm580. I'm thinking the best option is to just use a 120 rad on gpu and a 120 on cpu on the topside, but if its possible to use a 92mm aio at the bottom i would like to utilize that. If anyone has advice would appreciate it.
Thanks and hope ya'll are doing well.
Officially, the 645LT isn't compatible in the 570/580, just have to point that out ;pBased on my experience, you can place 645LT in both SM570 (with/without sliger 645LT bracket) or SM580 (without bracket with washers).
@KSliger : any news about pcie gen 4 riser please?..![]()
Ok thanks. Answer on sm570/580 with 645lt is due to any specific reason?Officially, the 645LT isn't compatible in the 570/580, just have to point that out ;p
4.0 riser is still pretty delayed. It was fairly low priority previous to the whole covid-19 situation, so it's been solidly back-burner-ed. We're hoping to have something ready by late summer!
There's ~3mm less clearance under the center rib on the 570/80 vs the 550/60. It "can" fit, but ventures into the realm of we can't guarantee it will!Ok thanks. Answer on sm570/580 with 645lt is due to any specific reason?
Good news for riser gen 4.0....it will be on time with ampere gpu..![]()
