Will there be a significant advantage of going with mini-sized GPU's with the SM570 or would full length dual-slot cards do just fine? I reckon that mini-sized ones are more expensive than their full length counterparts.
Go with full length dual slot, avoid blower cards if you can!
Hey
@KSliger will the Cerberus chrome feet set fit on the SM series or are planning on one in the future? I would definitely buy one to compliment this beauty, immediately!
Cerberus feet do work on these, might make the chrome feet an option on checkout later but for now you could snag them off the Cerberus page.
@KSliger no worries, I just got a nervous for a little while when you guys weren’t replying. If I was living in the US, I wouldn’t mind the delay but I have strict time constraints.
Jack reached out to me early in the morning though, so all is good. I just hope we can work out the quakecon coupon technicalities.
Appreciate the patience, glad Jack has you covered should get the coupon thing resolved tomorrow too!
Hello, I don't know English, so some places don't understand. I ordered the SM580 yesterday. When do you usually ship it?
Right now we are shipping in 6 days or less for stock configurations.
How the heck do I mount the radiator? I unscrewed the 4 screws from left and right of the case, the radiator holder won't come off.
Is the bracket stuck in the top? Shoot us an email with pictures if something doesn't seem right, it might just be stuck.
Will work on the user manual later this week.
@KSliger i got my sm580 coming this week. i know what the psu bracket looks like, but what exactly does the rad mount bracket look like?
Will post a picture of it tomorrow, shoot us an email if not. I have no pictures to post right now.
There is SOME possibility that I used the wrong THREAD for the PCIE backplate, but that should just jam and not break. The driver fit fine. It didn't strip at the screwdriver - it just plain broke.
Also - welcome back!
Did the other screws that looked the same thread in fine?
Yep! That under spine clearance PSU side is what I was asking about! Thank you!
I personally don't mind stainless screws
Edit:
@KSliger is this clearance the same for SM550/560?
I'll look into stainless if people keep having problems.
The SM550 / SM560 are different, think they are ~3mm less, will get that information posted.
