Had this case for roughly a year now, thought I would share some pictures and thoughts around the experience.
Ive previously built systems in a louqe ghost, DAN case and sliger s620.
The build currently has the following:
As monitor I use a AW3821 (38inch 3840x1600). Which the 3060ti can power adequently imo, throw in DLSS and its a good ”4k choice”. I previously used a EVGA 2060 KO in the build. Decent performance, but noisy card. This 3060ti XC feels like its built better, heatsink/fan design.
This case is perfect for me, its minimalistic and looks great, packs enough power to suit my needs (3060ti XC is a beast in a small format) and is fun to build in if you buy the right parts. Its not the cheapest case around, but I appreciate what it brings to the table and so its worth the cost.
My build is more or less dead silent on desktop use. While gaming its at a decent sound level, need to tune gpu/cpu to bring fan rpms down. undervolting GPU/CPU has negligible impact on gaming performance (In my experience).
- Asus rog strix B450-i (old but still a solid board with frequent bios updates)
- Ryzen 5600x + Noctua L9a w/ fan duct
- Crucial ballistix 2x16gb ram (@3800MHz, 1:1 IF, CL16)
- EVGA 3060ti XC (ace card)
- Intel 1tb nvme.
- HDplex AC/DC + DC/DC 400w Combo (been very solid and silent)
- NFC accessories
- 3d bezel (smoke something..).. looks rad, but now hidden behind monitor
- power button
- Custom 24pin cable + CPU power
- power cable + gx16 connector
- got the machined feet too, but currently not used.
- 1830MHz @ 0.85v (though at times it pushes up to 1845…) Been rock stable. 0.83v crashed randomly in games, 0.84v was OK, so put it at 0.85v for some ”safety buffer”:
- Fans max out at 70%
- Cyberpunk/Vanguard temps after a while are around 70/85 (gpu/hotsspot)
- Run it at ECO mode (45w). Not much impact on games @ 3840x1600
- CO - (15-20) depending on core
- L9a fan capped at 70%
- Temps go up to around 80ish in games or Cinebench20.
