Wenemun submitted a new resource:
Silverstone Argon AR11 Cooler - Low Profile CPU Cooler
The Argon series coolers are designed to provide great cooling performance for CPUs. The Argon AR11, at 47mm high including fan, features four 6mm thick copper heat pipes connected to the base using heat-pipe direct contact (HDC) technology. By utilizing advanced manufacturing techniques, the heat pipes have unusually tight bends so they do not protrude to take up valuable spaces around CPU and reduce component interference when installed. A highly efficient and compact 92mm PWM fan tuned...
