Silverstone Argon AR11 Cooler
.SKP Silverstone Argon AR11 Cooler 2018-11-28
The Argon series coolers are designed to provide great cooling performance for CPUs. The Argon AR11, at 47mm high including fan, features four 6mm thick copper heat pipes connected to the base using heat-pipe direct contact (HDC) technology. By utilizing advanced manufacturing techniques, the heat pipes have unusually tight bends so they do not protrude to take up valuable spaces around CPU and reduce component interference when installed. A highly efficient and compact 92mm PWM fan tuned for optimal balance of airflow and noise is included to provide up to 95W of cooling power (or more in chassis with efficient airflow). For users requiring enhanced performance in space constrained applications, the high quality and affordable AR11 is one of the best choices on the market.
This resource has no feet and no fan (The fan is terrible anyway, replace with a noctua) but is to scale and has individual fans, heatpipes and baseplate components.
Author
Wenemun
Downloads
Views
1,222
First release
Last update
Rating
0.00 star(s) 0 ratings
More resources from Wenemun
