Recently, I looked at SilverStone’s VT02 – a subtle Mini-STX case along the lines of the ASRock DeskMini styling. Aftermarket cases for the M-STX form factor aren’t exactly common, but SilverStone does have two compatible models in the range – today’s review is of the VT01, the cheaper sibling to the VT02.
Inspired by the SilverStone TJ07 – an iconic (albeit huge) case of years gone, the VT01 is an ultra small case for the SFF generation. Built entirely from SECC steel, the VT01 isn’t exactly a pure descendant of the TJ07, but it does offer great value and a different take on the uSFF market segment from the little black boxes we are used to seeing.
Let’s take a deeper look!
The Specs
Model
SST-VT01S
Materials
0.8mm SECC
Motherboard
Mini-STX
Drive Bays
2.5″ x 1 (thickness≦9.5mm) internal
Front IO
USB 3.0 (Type-A) x 1
USB 3.0 (Type-C) x 1
Audio x 1
MIC x 1
CPU Cooler Limitation
34mm
Weight
582g
Dimensions
155mm (W) x...
Continue reading...
