so we know now : DESKMINI A300 has 3+2 phase design dEskmini X300 4+1 .. so you should can better overclock the gpu on the a300 ? Or have booth 3+ 2 Phases designmore details on X300 (test sytem runs on bios P1.10)
i'm 99% sure that actual hardware for A300 and X300 are identical. see my quick comparison of the two motherboards (picture sources: left side techspot.com review, right side wccftech.com article).
my notes:
- same REV 1.02 revision marking for sure
- X300-STX seems to be a simple sticker(exact same but rebranded PCB? how lame if true!)
i think it is wrong that there ist another phase design on deskmini a300 ... real more you can't geht with 4 phases and the 4750g . Somebody that i know have tested it. You have 4,3 ghz allcore and the vrms aren't soo hoot . good they warm but it is ok he said. If the x300 4++1 should have... you don't have an real advantage. Because with one phase you can't overclock the gpu as with two phases and here you can get lots of preformance on a deskmini. Because the Ram can ran with 4000 @1,35 and bit over with an 3600 cl 16 kit and you can get lots off preformance with high speed ram and gpu oc.3+2 is 3 phase for the CPU, 2 for the SOC and GPU. The chip that handles the phases, the RT3667BB, can be configured for both 3+2 or 4+1. However, it would be interesting if it actually is configured as 4+1, as that would require some trace rerouting and harm the overclock ability of the SOC and iGPU (assuming the 4000 series of APUs route power the same as the 2000 and 3000 series). Maybe they needed to do this to allow for an 8 core APU?
I'm also interested in seeing if the capacitors on the bottom are not all populated like on the a300 board.
so Renoir@A300 as unofficial supportThe DeskMini X300 is for the latest AMD Renoir CPU. Our official website won't provide the BIOS for A300 to support Renoir CPU. If there's any issue when user updates the BIOS on A300, we won't guarantee the functions and will not be able to help with any warranty support.
ASRock
RAM, CPU, APU OC without any problems. 120Watt PSUJetzt neu: Overclocking von CPU und RAM funktioniert
Eine Neuheit beim DeskMini X300 von ASRock ist die per BIOS freigegebene Möglichkeit zum Übertakten. Und das geht nicht nur mit dem DDR4-Speicher, sondern auch mit dem Prozessorteil sowie der integrierten Grafik. Überall kann der Takt manuell eingestellt werden.
Im Test klappte das problemlos.
you can buy an a300 and install a bios what you want is the same as the x300 no changes i think. if the X300 have 4+1 phases (realtak if, I don't believe that i think its an 3+2 vrm design) you have to the a300 an disadvantage. Because in theory you can better oc the gpu if it should possible. There you have more advantage if you can better oc the gpu instead the cpu on a deskmini (x)= x, a 300 series.Oh Look at this:
ASRock DeskMini X300 im Test
Nach dem Erfolg des A300 legt ASRock mit dem X300 ein überarbeitetes Modell auf, das an die Stärken anknüpft und Ergänzungen hinzufügt.www.computerbase.de
1) sad things about A300 official renoir support, time for X300 oc bios hacking/backporting i guess. using "unofficial" (still perfectly working) beta bios till ethernity is not sexy.
2) LED RGB strip as additional accessories, lol.
3) 120W psu is not enough for 4750g oc. just take a look at the full power consumption of 4350g mentioned (87W).
4) it's finally confirmed that X300 replaces A300 and price will be max €30 more. so at the end of the day users will get a price increase almost equal to a good 3rd party low profile cooler with not much in return. asrock should just bundle a noctua nh-l9a instead of the noisy stock cooler and increase msrp to $170. this move alone would make oc a real possibility out of the box, and we would get real value for the extra money. or just get rid of the stock cooler, cut price to the original $150 and call it X300 pure edition![]()
nice videodeskmini a300 with an 4750g
what did they realtalk ? what do they ? No realtalkI find it weird that on JZ Electronic they warn that you can't go over 2666Mhz with the new 4750G:
Konfigurator
Der Computer Konfigurator für ASRock A300 DeskMini Serie und jetzt mit der neuen AMD® CPU 2000 Serie.shop.jzelectronic.de
"* This APU (Renoir) does not support the S3 mode (energy saving) in the DeskMini A300!
Info! The Ryzen 7 Pro 4750G can currently max. can be set with PC2666! "
PS : look at thatwhat did they realtalk ? what do they ? No realtalkthats wrong
I know what he testing
And its example show. It works faster then 2666 .
I tst 1.4 at deskmini a300@alles_alles Yea, U need to get an updated version.
It is seems your AMiBCP is outdated and supports only 1 BIOS language
But than again, want is your desired outcome sind this tool?
- aquire some XP
- try to get something running? - I doubt that's possible. Maybe you have to enable more items for the SOC VID to show up. I kept mine with least changes. Therefore it did flash but no wanted outcome was visible.
Btw. I'm still having issues @XMP profile (3200, cl18) using 3.60S. although the vdrop is only 0.1V (which increases stability) unfortunately my sample wants a higher voltage to be applied. 0.1375 vs 0.1V the 3.60S gives us. ->> I'm back on R
This behavior may change when I upgrade to 46xx/47xx or it won't change - then I know I have a faulty power delivery on A300 mainboard.
[3+2] phase design was like 3 phased for the CPU, One phase for SoC and one for APU? Or 2 phases for SOC+APU. I don't remember.
A change in phase-configuration could achieve desired stability results. We'll have somehow to acquire high-res x300 mainboard pictures
Is JZ from JZ computer de also here in forum? I know he has one X300 with P1.40 currently testing.
Maybe we could ask him to provide some high res pics + the "activator chip" should have a different marking (at least one char should differ)
Greetings
have change my cpu to the 2400g for now . can test it again and make a screen. what do you mean with cheat ?Can you provide any CPU-Z? Oder HWinfo for GPU part? You may be cheated by the BIOS
don't know if i set a frequenz and go to bios it shows at the first site the frequenz what i set ?have change my cpu to the 2400g for now . can test it again and make a screen. what do you mean with cheat ?
