I don't follow, what exactly do you mean by "splitting the 8-pin of the HDPLEX"?At stock clocks splitting the 8-pin of the HDPLEX shouldn't be an issue.
I certainly hope so. I'd totally upgrade from my HDPLEX-300 and my Dell-330W to a G-Unique 400w and modded Dell-400w. or maybe I'd spring for a 500W and 500W modded Power brick?
But guys, big problem, its running off of 2x 8-pin GPU power... No HDPLEX has that many GPU-pin power cables...
I'm pretty sure he/I means something like thisI don't follow, what exactly do you mean by "splitting the 8-pin of the HDPLEX"?
Hmmm, that seems interesting, how the hell do you get 1 8-pin power connection and properly split it into 2x 8-pins? dont they both have to be native 8-pins? I always thought this was similar to using a molex to GPU-power pin connector, which was usually considered bad... Maybe I'm missing something here? lolI'm pretty sure he/I means something like this
or like this
That way you can have just one 8pin connector on the PSU end but 2 connectors on the Card end
what is Dynamo though? And btw don't have buyers remorse, I feel it a bit too, but let's be honest... do we really NEED that much power? Sure if we bought a 1080mini day-1 it might've cost us over $700 USD, where this card will probably cost roughly the same amount now that the 1080's have had their price drop with the introduction of the Ti series.... but do we really NEED a 1080 Ti's power? Not unless we're striving for 4K gaming at 50-60FPS on ultra.Dynamo will run it too (2 x 8 pin and higher overhead). Definitely having buyer's remorse on the 1080 mini right now![]()
Interesting.As far as I understand it it'd just a matter of getting the right voltages to the right pins on the connectors so essentially all you'd do is put two wires per pin on the PSU end 8pin connector and then just put them in the correct pins on the Card end.
As I understand it the reason using Molex to power a GPU is frowned upon basically comes down to that generally the rail that its attached to in the PSU isn't meant to supply as much current as a GPU might need and thus could cause issues. This is why I said we should check with Larry so that we know what wattage output the 8pin PCIe connector is capable of so we don't cause any issues by turning it into a dual 8pin.
Yes! So it should be possible, sweet. So the only issue/limiter would be coil whine from the 1080Ti or from the HDPLEX-400, which the HDPLEX-400 should have less of anyway, supposedly, lol.The maximum rated wattage per 8 pin connector is 150W, but realistically they should be able to supply more. The limiting factor with a split 8 pin like you're talking about would likely be the connector ratings on the PSU end. Female Minifit Jr connectors have a max rated amperage of 9A I believe. In the case of the HDPlex they use 4 12V lines (some PSUs use three) which means you can hypothetically move 432W which is more than enough for even the most violently spiking GPU this generation. If you were trying this with a conventional PSU that provides 3 12V lines to the GPU you'd be looking at a max rated wattage of 324W which would potentially cause problems.
Realistically I think the more likely problem you're going to run into pushing a 1080Ti and say 7700K on this unit is possibly coil whine. The major objective as I understand it to providing the added headroom on this unit was to eliminate the coil whine we saw in the last generation.
what directions do you have to follow, to get them to ship to the USA ???If anyone is looking for a black S4 mini and does not want to wait till September, Dreamcore.com.sg sells the case as well. The cost is the same as if you bought it from Josh direct.
Savage! I can't believe this is happening. So the S4 Mini can actually have a single-GPU god-build?!
I'm not sure how but you can try messaging them on Facebook https://www.facebook.com/dreamcoresg/ or emailing them at hello@dreamcore.com.sgwhat directions do you have to follow, to get them to ship to the USA ???
has anyone on this forum, located in USA, ever gotten one from them ??I'm not sure how but you can try messaging them on Facebook https://www.facebook.com/dreamcoresg/ or emailing them at hello@dreamcore.com.sg
