as promised in my original thread, here are the files to make your own Tripple Fan Mod & Copper Heat Sink for the A2000...
you will need:
I have attached the drawings to this post, feel free to use for your own personal mods...
you will need:
- Silverstone 5010 fans
- Copper Heat Sink
- M2x6 self cutting screws, M2.5x8 screws, 1mm plastic washers
- STEP for the 3D printed shroud and DXF for milling the heat sink
- optional: backplate and memory shim
- solder skills or a DIY fan splitter cable
