Prototype REVOCCASES RCC-DTC1 | 9.5L classic layout desktop case
REVOCCASES
REVOCCASES
2,165
3,504
www.revoccases.com
DTC1 is a DIY friendly case inspired by a post from reddit user /k0nl1e and modified together with @Diamorif on my Discord group
Specs:
  • ITX Motherboard
  • SFX PSU
  • 3-Slot 270x126mm GPU (absolute max. incl. power cables)
  • 122mm CPU cooler clearance
  • 120mm slim case fan
  • overall dimensions: 245x273x142mm (9.5L)
I've attached the drawings for laser cutting and bending to this post. Feel free to use for your own DIY case projects.
build by @Diamorif
  • RCC-DTC1.zip
REVOCCASES
REVOCCASES
2,165
3,504
www.revoccases.com
sorry for the necro, but @Hewligan was so nice and send me back one of the prototypes so I could finally put a proper build together in the DTC1 - right in time for the holidays... 🎄
the build features:
  • RTX 3060Ti
  • BIOSTAR B660T SILVER ITX
  • EVGA SuperNOVA GM 550W
  • 32G 3600 RAM
  • TEAMGROUP MP33 1T SSD
  • i5 12400F
  • Intel AC WiFi / BT Combo
  • Thermaltake Toughair 110
  • Arctic P12 Slim
REVOCCASES
REVOCCASES
2,165
3,504
www.revoccases.com
k0n
233
313
Only see this now :) I'm also active here (@k0n ..)
What I love about this is that mini-ITX has a real advantage here! With the fins oriented like this the card can exhaust to both sides, no unnecessary PCB that is blocking one side.
REVOCCASES
REVOCCASES
2,165
3,504
www.revoccases.com
Oh, nice! Didn't know you were also active here...
Indeed, your layout is very well thought of. No riser, good airflow for the GPU and enough space for a good CPU air cooler 👏
