Concept REVOCCASES - next (low cost) case design - what would you prefer
APU1 - you can help to decide in which direction it shall go
  • larger with more cooling options
    Votes: 2 11.1%
  • as small as possible
    Votes: 12 66.7%
  • none, I would prefer full length GPU support
    Votes: 4 22.2%
  • Total voters
  • Poll closed .
REVOCCASES
REVOCCASES
2,222
3,639
www.revoccases.com
  • BASE Case: Apu or LP GPU dual slot, up to 200W brickless or /w brick and larger coolers
  • PSU Extension Case: FLEX, HDplex 200W, MEANWELL up to 500W
  • GPU Extension Case: Full length dual slot
Reactions: FischOderAal
FischOderAal
73
77
From my point of view the most sensible NAS configuration is RAID 5, so 3x3.5 HDDs. Minimum would be RAID1, so two HDDs. Don't know what fits :)
FischOderAal
73
77
Maybe it would make more sense to make a case for two 5,25" trays. this way people can also use the case for optical disc drives. For HDDs you can use adapters or quick swap cases (there are also 3D printed ones).
REVOCCASES
REVOCCASES
2,222
3,639
www.revoccases.com
All good ideas, let me think about this. I'll probably release the mods/extensions step by step. First I have to make a working prototype of the "base case". ;)
REVOCCASES
REVOCCASES
2,222
3,639
www.revoccases.com
for the GPU / HDD extension, what would you prefer:
  • support for 80x10mm case fans and 2.5 slot GPUs (300x85x194mm)
  • only vent slots, no additional case fans, 2 slot GPUs (300x70x194mm)
oOflyeyesOo
120
55
Could the GPU/hdd case be adjustable in height? A basic track on the end, to adjust to multiple fans sizes, and could be slimmer for hard drives.
FischOderAal
73
77
2,5 slot would be my choice. In the end 15 mm height difference is negligible but it gives you more opportunities.
