Reverse Ncase Power Cable
Soulforger90
48
The v6.1 reverse style power cable order arrived a few days ago. Thanks ncase! The original was giving me OCD being bent around like that.
Apparently mine is out for delivery today! Also bought a 92mm fan for the back of the case, along with a 120mm A12x25 to do some testing. I want to see how much of a difference the A12 vs the stock 140mm makes, if any.
YESWEKEN
31
31
as of 5pm 1/6/2020 pacific, the power cable is back on "pre-order" status, you can choose left or right orientation
secure-address
Right angle version is sold out. Sad face.
sunrainsky
35
I'm in the same predicament. Actually right angle left isn't ideal either, "right angle up" towards the back of the case would be best. Like this image.
Interesting. Can I ask, are you referring to when the socket position is the middle at the back of the case, you are intending to have a straight vertical line to the SFX power supply in the ATX position?
I am asking because my current setup has the SFX power supply in the ATX position due to the Noctua C14S and I find that the left oriented cable works fine for me since I want to avoid going straight across (adds a bulge).
I do see why a right oriented cable will be needed when the PSU fan needs to face out in the stock position.
