Replacing VRM heatsinks with smaller ones?
zovc
852
602
Hey!
I had to try another motherboard out for my build and the only one with the Z97 chipset I could get a hold of was the Asus Z97i-Plus. It ended up solving my issues, but it's got a huge heatsink that blocks my Noctua NH-L9i from being able to exhaust in one direction.
As you can see, "above" the CPU socket is a large heatsink. It's got screws on the bottom side of the board, so it looks like it could be removed. This heatsink is blocking basically the only place my CPU cooler can dissapate heat, since the RAM is on one side, the I/O is on the opposite side, and my GPU is opposite of that big heatsink.
I've seen folks attach extruded heatsinks on components (including even motherboard VRMs) before, is it possible I could do something like that and achieve okay results?
zovc
852
602
If it helps, here's a picture of the back of the board. The screws that attach that heatsink are visible above the CPU backplate and cooler mounting points.
Editorial Staff
Moderator
5,184
4,519
It seems easily possible. It seems like the heatsink uses screws on the back of the board. I'd recommend you look into these:
Enzotech has these. This will allow your CPU to vent heat out the side of the VRMs and cool them at the same time.
zovc
852
602
This looks even nicer than what I was thinking of. I'll look into those!
zovc
852
602
What should I use to attach these things? I'll probably order some and try working with them next week, life permitting.
fabio
Shrink Way Wielder
1,850
4,266
The enzotech ones work fantastic if they fit for your application.
Do you think these can sustain the mosfet heat on an Asus Z390 Strix ITX? I would like to remove that weird-nosense heatsink/shroud all together!
Josh | NFC
Not From Concentrate
NFC Systems
1,866
4,431
www.nfc-systems.com
I've completed many build without any heatsinks on the mosfets and no complaints from the customs from crashes or bad clocks so far. So I think it would just be icing on the cake. :)
fabio
Shrink Way Wielder
1,850
4,266
Thanks a lot!
GuilleAcoustic
Chief Procrastination Officer
Moderator
LOSIAS
Jun 29, 2015
2,298
3,396
guilleacoustic.wordpress.com
Reactions: fabio
