Enclosure Regarding tooless panels
jtd871
1,166
851
Probably should ask in Custom Cases and Projects. "Hardware" covers finished or 'commercial' components rather than actual hardware (fasteners, tools, etc.).
Necere
NCASE
3,284
So I guess this goes in hardware (if not, mods please move @ your discretion). I mean, PEMSERTs are technically hardware, right?
So in making a tooless panel, you use these, correct?
https://catalog.pemnet.com/category/snap-top-standoffs-types-ssa-ssc-sss
And Is there space issues? Has anyone used these?
Never seen those used for fastening panels. I think they're intended more for mounting PCBs.
The stud & clips Lian Li uses are proprietary to them, though some other companies have their own versions. The closest off-the-shelf hardware I'm aware of are these, which are what Sliger uses in the Cerberus.
KMPKT
3,382
5,936
Caselabs also sells/uses those connectors. Might be worth hitting them up to see if they're clearing any out.
KSliger
Sliger Designs
May 8, 2015
855
3,186
They're amazing for tooless panels, only issue is that the minimum length on them is hard to work with - and the longest one doesn't give much room to fit stuff under it.
Reactions: Windfall
