CPU Rebuild Options
Arboreal
818
814
I'm currently running a Strix X470i / R5 2600x / GTX 1650 Aero ITX in my Dan Case A4 SFX and have just secured a new set of kit. For reference, my main gamer is a Strix H370i / i5 8400 / GTX 980Ti in a Sliger S610.
I bought the A4 to go lighter for LAN nights, as I missed the lightness of my NCase M1.
I have acquired a Vision Z590i / i5 11400F combo and a Gigabyte GTX 1080 Windforce. My (not so extreme SFF) friend that I got the i5 from suggested that the 11400F would run too hot in the A4 SFX and it should go in the S610.
I currently have a Thermalright AXP120-X67 which will only fit 'Hotrod' style like my Wraith Spire is at the moment! I have a standard Cryorig C7 in teh drawer that I can use, but would go for a Thermalright AXP90-X47 full copper if the 11400F is not too hot.
As far as i can tell, he's been running it with the power limits maxed out, and realise I'll need to rein it in on the A4.
Is he right? I am happy to limit the power to get to use the A4
Solo
894
1,500
I've been running various 6 cores with L9i's for like a million years. I'm pretty certain you'll be fine with the AXP90.
Reactions: Arboreal
Gingerbeer
119
105
You can get intel mounts for the NH-L9a which might offer a teeny bit more thermal headroom, though you lose the ability of the L9i to choose the airflow direction.
[Edit] wait, the A4 can take a Blackridge cooler, and that can handle my 5800x3D
Reactions: Arboreal
Arboreal
818
814
Good call on the extra L9a cooling. Not sure how the AXP 90 Copper compares. It's AXP 120 Hotrod or C7 for starters...
