Raijintek Thetis: Another small ATX case
AcquaCow
113
84
Anyone else eyeing any new SFF ATX options?
Going to be building a new box soon with a 7950x and will be going full ATX yet again. Not sure I want to cram everything into my thetis, or start from scratch in another case...
MarcParis
Apr 1, 2016
3,597
2,676
Cerberus-X or N-ATX v2 are best SFF ATX available so far.
fma965
I'm back again.... Upgrade time :)
Replaced the 3090 FE with a 4090 FE, but this will be my last change in this case as i am moving to the Jonsbo D41 once it arrives from china as it has more radiator room, this is pushing the thermal limits now lmfao
Terrible picture but as i am awaiting a new case it's not getting any cleaner
PCPartPicker Part List
CPU: AMD Ryzen 9 5900X 3.7 GHz 12-Core Processor (Purchased For £449.99)
Thermal Compound: Thermal Grizzly Hydronaut 3.9 g Thermal Paste (Purchased For £8.99)
Motherboard: Asus ROG Strix X570-F Gaming ATX AM4 Motherboard (Purchased For £279.99)
Memory: Corsair Vengeance LPX 32 GB (4 x 8 GB) DDR4-3600 CL18 Memory (Purchased For £178.99)
Storage: Western Digital Black SN750 2 TB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive (Purchased For £110.99)
Storage: Seagate FireCuda 530 4 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive (Purchased For £399.00)
Video Card: NVIDIA Founders Edition GeForce RTX 4090 24 GB Video Card (Purchased For £1599.99)
Case: RAIJINTEK Thetis ATX Mid Tower Case (Purchased For £102.49)
Power Supply: SeaSonic FOCUS GX 1000 W 80+ Gold Certified Fully Modular ATX Power Supply (Purchased For £149.99)
Wired Network Adapter: Asus XG-C100C 10 Gb/s Ethernet PCIe x4 Network Adapter (Purchased For £68.99)
Case Fan: Corsair ML120 75 CFM 120 mm Fans 2-Pack (Purchased For £22.99)
Monitor: Asus PB277Q 27.0" 2560 x 1440 75 Hz Monitor (Purchased For £274.99)
Monitor: Samsung Odyssey G9 49.0" 5120 x 1440 240 Hz Curved Monitor (Purchased For £1115.29)
Keyboard: Logitech G915 TKL RGB Wireless Gaming Keyboard (Purchased For £149.25)
Mouse: Logitech G Pro Wireless Wireless Optical Mouse (Purchased For £90.00)
Headphones: Astro A50 + Base Station Headset (Purchased For £199.99)
Speakers: Logitech G560 120 W 2.1 Channel Speakers (Purchased For £99.00)
Custom: Blue Microphones Yeti USB Microphone - Blackout Edition (Purchased For £99.99)
Custom: Neewer NB-35 Black Microphone Suspension Boom Scissor Arm Stand with Mic Clip Holder and Table Mounting Clamp & NW(B-3) Black Pop Filter Windscreen Mask Shield with Stand Clip Kit (Purchased For £14.99)
Custom: Elgato Stream Deck - Live Content Creation Controller (Purchased For £139.99)
Custom: KLIM Bungee Extension for Mouse - 3 x USB 3.0 Hub - Multi Functional - High Quality Product - Backlit - Cable Organiser - 5 Year Warranty - [ New 2017 Version ] Black (Purchased For £17.90)
Custom: Speclux Magnetic LED Strip, Addressable PC LED, Digital RGB Strip, 50cm (Purchased For £13.99)
Custom: TP-Link UH720 7-Port USB 3.0 Hub with 2 Exclusive 2.4 A Charging Ports, Anti-static Protection, Black (Purchased For £34.98)
Custom: Oculus Quest 2 - 64 GB (Purchased For £299.99)
Custom: Secretlab Titan 2020 Softweave Fabric Gaming Chair - Charcoal Blue (Purchased For £240.00)
Custom: ORICO USB 3.0 Hub Clamp Adapter, Aluminum 4-Port USB Splitter with Extra Power Supply Port and 4.92 FT USB Data Cable, Ultra-Portable USB Expander for 2021 iMac/Laptop/PC (Purchased For £15.99)
Custom: SSK USB C 3.2 Gen 2 Hub 10Gbps, 4-in-1 SuperSpeed USB Type C Multiport Adapter with 2 USB C 2 USB A 3.1/3.2 Gen2 10Gbps Ports,USB C Dock for iMac/MacBook/Pro/Air(Not for monitor) (Purchased For £18.95)
Custom: EK-CoolStream PE 120 Single Radiator (Purchased For £39.99)
Custom: EK-CoolStream PE 240 Dual Radiator (Purchased For £59.99)
Custom: EK-Quantum Kinetic Pump/Reservoir (Purchased For £149.99)
Custom: 3 Meter Bykski 10x13 Tubing PVC - Black (Purchased For £4.99)
Custom: EK-Quantum Momentum ROG Strix X570-E D-RGB - Plexi Mono Waterblock (Purchased For £124.99)
Custom: EK WATER BLOCKS EK-CRYOFUEL CLEAR (PREMIX 1000ML) (Purchased For £7.99)
Custom: Glorious PC Gaming Race Stealth Keyboard Wrist Rest Slim - TKL, Black (Purchased For £19.99)
Custom: LINDY Single Screen Bracket with Pole and Desk Clamp for 30-Inch LCD/LED Monitor - Black (Purchased For £14.87)
Custom: Various Watercooling Fittings (Purchased For £50.00)
Custom: XBOX Elite Series 2 Wireless Controller - Black (Purchased For £173.00)
Custom: UTESPELARE Gaming desk (Purchased For £150.00)
Custom: EK-Quantum Vector² FE GeForce RTX 4090 D-RGB Graphics Card Water Block (Purchased For £199.99)
Custom: Integral V Series 2TB SATA III 2.5 Inch Internal SSD (Purchased For £93.48)
Total: £7309.95
Prices include shipping, taxes, and discounts when available
Generated by PCPartPicker 2023-01-15 12:07 GMT+0000
  • Love
Reactions: MarcParis
MarcParis
Apr 1, 2016
3,597
2,676
Clean & great setup!
What about thermals? It should be not that bad I assume.
fma965
Not sure clean is the correct word 😂, thermals are not great but plenty reasonable (for only a 240mm + 120mm rad). Liquid gets to like 50c, GPU to like 70c (under intense load, usually only about 50c), CPU about 60c
The new case will allow me to have 360mm + 240mm/360mm :)
