I'm just figuring out what RAM and NVME to buy for a 3950x build with a B550 or X570 mobo (itx)
Gigabyte seem to not have any 32gb or 64gb ram kits in B550 or X570 at all, and the Corsair Vengeance Pro LPX kits seem thin on the ground for being qualified by Gigabyte. It's almost like they're testing sticks, not kits, but kits made up of qualified sticks are not shown?
Asus have the Aorus PCI-E nvme in their list, but only in 500gb size, no mention of 1tb and 2tb sizes.
I can't believe Gigabyte haven't done QVL on 32gb or 64gb kits, so am I missing something when I read their lists?
And Asus only testing one nvme from the Aorus nvme range? Is the inference that if they tested one then they should all be ok with these types of devices?
I'm looking for a workstation type build so stability is really important. I know the QVL doesn't guarantee stability but it's a good start.
I'm buying parts from Scan computers in the UK, and it seems sensible to buy all the main core bits from the same place in case there are issues I can just dump all their bits back on them... but their RAM offerings are really limited.
Thanks
Thanks
