Log PC SX4 18L by Custom_MOD
sergiiua
CustomMOD
Jan 11, 2017
1,135
2,027
www.custom-mod.com
The SX4 18L computer was custom made. As a basis, we took the drawings of the SX3 11L case and enlarged it to the size we needed.
FEATURES
  • Aluminum body and solid Steel frame.
  • Smart Glass with 60V Power
  • 12-60V converter inside the case
  • SFX Power Supply
  • Liquid Cooling System
  • External Tank EKWB with pump D5
  • Installed G4 Dust Filters
PC specification
  • Size: H 290mm x L 350mm x W 180mm
  • Material: Aluminum (1mm); Steel (1mm); SMART Glass (3.2mm) with 12-60V converter
  • MB: ASUS CROSSHAIR VIII IMPACT
  • CPU: AMD RYZEN 9 3950X
  • RAM: CORSAIR DOMINATOR 32Gb 3466MHz
  • GPU: GIGABYTE RTX2080 super WB
  • PSU: CORSAIR SF750 platinum
  • SSD: 2x SEAGATE FireCuda520 Gen4 512Mb / 1Tb
  • CASE FANs: Noctua NF-A15; NF-F12; NF-A9x14
  • WaterCool:
  • EK Quantum Kinetic FLT240 D5
  • EK-Velocity D-RGB - AMD nickel
  • OCOOL NexXxoS ST30 x 280
  • FANs: 2x NOCTUA industrialPPC 3000
  • Water flow Sensor: FREZEMOD
  • Fittings: EKWB Black Nickel
  • WATER: EK CRYOFUEL RED 1L
Video in Russian
Reactions: Windfall and dealda
