Hey All!
I've been a long time lurker of this forum and have really been loving all the Artisan builds that are underway and the concepts behind them! Given my own personal goals for Minimalism, I've sort of thrown together a very crude idea of a possible project I'd like to undergo.
Now I would like to say that this is a niche concept, It wont cater to the masses but most definitely caters to my needs.
So I want to keep it lower than 100mm. Sporting two 92mm fans as intake, hoping that it will prevent the components from being starved for air. I recently underwent a NES pc build and found that temperatures where up in the nineties without sufficient airflow, So with this build I plan to eradicate that issue by keeping it small and having the two fans blast air into the chassis.
I'll be using a HDPlex 250w PSU inside, In order to keep this as small as possible. Anyone with experience with HDplex products knows that these things are amazing products. I currently have an i3 6100 in my rig at the moment, Given the release of the 1060, I plan to have one of those inside the build in either Zotac's or EVGA's ITX version, The R9 Nano is simply a placeholder. In making this decision, I've pretty much narrowed myself into a corner with power draw and card length. From benchmarks that I've seen, a 1060 is pretty much a 980 on paper. That for me would be more than enough for a 1080p setup.
I realize that there's very little room between the CPU and the GPU, I'm planning on using the Noctua NH-L9i. I'm aware of the Overclock limitations of the cpu cooler as well as the possible thermal issues, but I don't plan on over clocking and hopefully with the front intake fans, temps won't become an issue.
Would love to hear your thoughts and some input on the design and possible issues I may encounter! Would also be amazing if anyone had a good idea of how to get my model into AutoCad and out of Sketchup (I tried to dabble in AutoCAD but failed miserably).
