Hi all, I have a bit of conundrum with my next PC build. I bought my case, Silverstone RVZ02 and it has a chambered compartment for the motherboard/PSU and GPU. I've been looking for technical articles and found several that indicates that for SFF builds, it's best for a small case to use blower style GPU like for example this article http://techbuyersguru.com/video-card-comparison-blower-style-vs-open-air-coolers?page=2
However, the case used is Silverstone SG08 with only one chamber which is obviously with an open air GPU, then the heat will dissipated inside the case,
My question is will an open air GPU works better inside a chambered case like the RVZ02? I bought the window version, and basically the window is just a massive opening for both chambers (for the motherboard/PSU and the GPU).
So I assume, the hot air can evacuate faster especially with the added benefit of open air fan design that blows air to the surface of the GPU heatsink evenly.
Anyone using the same setup that can share or any general knowledge about chambered casing in general? Any input is much appreciated.
