I modded an Arctic P12 120x25mm fan so it'd fit under a NH-L12S then threw it in my Ncase M1. Previously I had the ID-Cooling SE 914 XT (Noctua U9S copycat) with a Noctua 92x25 mounted on the cooler, and another Noctua 92x25 mounted on the rear of the case. Both of the Noctua fans were set to exhaust out the rear. For my testing I ran all case fans at 70% and my 3070 FE fans at 30% (the minimum). The GPU is +125/+1000 overclocked and the 5600X CPU has PBO enabled with no manual under/overclocking. I then opened Cyberpunk 2077 and left it for 10 minutes. I chose that game because it uses the CPU a lot more than other games while keeping the GPU at 100% utilization.
The NH-L12S CPU temp was 3.5C lower than the U9S copycat, and the GPU temp was 4.0C lower. Additionally, the overall noise was lower as well due to 120x25 fans being used instead of 92x25 ones.
I also briefly tried an EK-120 AIO and the NH-L12S with the 120x25mm fan beat that as well surprisingly!
It's also important to note that the GPU temps are able to stay so low while at 30% fan speed due to two 120x25 Arctic P12s mounted underneath it in addition to an Arctic P12 exhausting out the side via a duct I designed and 3d printed.
Here are some photos! NH-L12S with a 120x25mm fan - Imgur
