Buying NFC S4 Mini
emojiyamamoto
Nvm, I think I found you. I'm very interested! I am strongly considering the power supply as well. I will get back to you soon.
nfilipac
I'll take the case for sure! What are the screws that's missing?
The way I ran the case, I had 2 ssds attached to the ssd/hdd mount (one with 3 screws, one with 4 screws), and I didn't use the fan bracket. This leads me to think I have 3 missing screws (I didn't have 1 to mount the SSD with, and I didn't have the two others to mount the fan bracket with.
If you want to use 2 ssds/hdds and the fan bracket, you would just mount 1 ssd with 2 screws, one with 3, and use the 2 left over for the fan bracket, if that makes sense.
nfilipac
Sorry if it's confusing. So when you said you were interested in the case, does that mean just the case, or the whole bundle?
So normally, the way you would attach the SSD or HDD to the mount is with 4 screws in the corners. However, you can use as few as 2 screws in opposite corners and it would still be secure imo. Idk if that helps
