So I just build myself a new mini PC SFF.
Here are the parts;
So I connected 2 old 2,5'' SSD and installed Win 11 on one of them after formating it.
It's been a very long time since I build my last PC so I;m lost now and don't know what to look for or what to change to make it work better.
One thing I can say is that it's A LOT slower then my old i7-11800H laptop.
The maximum Temp I can reach in a Stress Test in Core Temp is 50 degrees celcius but in normal situation it's pretty much always at 40 degrees celcius.
Here's a screenshot of HWinfo if that can help.
I don't know where to go from here and would really appreciate if someone can bring some guidance.
It takes about 2-3 seconds for Windows Explorer to open up and the top banner take a second more when it pop up.
I will make all the test you want if that can help and edit this first thread.
I downloaded Cinebench to stress/benchmark it but ti's taking 2 hours and 30 minutes to extract the zip. There's obviously something that is not right.
Thank you for your help.
Here are the parts;
- ASRock DeskMini X600
- AMD Ryzen™ 7 9700X
- Thermalright AXP-90 X47 Full Cooper
- Kingston Fury Impact XMP 32GB 6400M KF564S38IBK2-32
- Seagate FireCuda 540 SSD 2TB
