Thanks for the help. I eventually got another set of MNPCTECH feet same as the ones I had on my v5. They look great but the v6.1 bottom is slightly different from the v5 since it has the bottom filter and therefore the bottom surface is a bit uneven for the feet to bolt on to. I had to use a piece of closed cell foam on each to make them straight. But in the end I’m happy with the result. Cheers.
