New member with a new Ncase M1 v6.1 and Asus X570-I and I'm having an issue with the front HD audio connector.
The mobo pins are slightly under 9mm across measuring from pin 1 to pin 5 and the front HD audio connector measuring the same is slightly >10mm.
I've been building computers since the Celeron days and have never had to try and apply this much pressure to mate. I ended up bending a couple pins on the mobo.
Anyone else had this issue? Did a get a out of spec cable? TIA
Mobo Audio Pins - 9mm
Front HD Audio Connector - >10mm
